Hi,
Is there a Plugin or Add on available for Photofiltre 6.4 that will give it perspective altering ability?
Thanks,
...... john
Transformation or Perspective plugin
Shinnen
- Mémoire RAM : 1.5 gig
Re: Transformation or Perspective plugin
Hi,
You don't need a specific plugin, many good tools are in the box.
http://photofiltre.free.fr/tutoriels/carte_en.htm
When you want transform a shape, do a right clic in the selection / Transform / Distort
The Studio release has a special visual tool with preview, grid and handles to correct perspective distortions.
Shinnen
Hi Tom,
Yes...... I found it. That should do what I want.
Thanks,
..... john
Thanks,
..... john
