A novice needs help - just started with this area!
some pictures look very dark compared to the original viewed in Microsoft Picture manager, when I open them with Photofiltre.
How come? and can I change it?
Picture is very dark compared to original
csjensen
Re: Picture is very dark compared to original
For example ? which type of file ? Which release of PhotoFiltre ?
csjensen
thanks for that question - that helped.
By changing to gif format from jpg, everything is ok...
But your answer does not help to identify the situation :
gif format support only 256 colours instead of 16 millions
csjensen
I have PhotoFiltre 6.4.0, and it was a jpg file.
I learned that gif was not the right format, since I could not edit much in the picture. Then by changing to png, it seems for the unexperience person as if the problem is solved.
But can you help me with how to show the examples here, then I will gladly do it?
Yes Png file format is better to save without any loss but this format is more heavy than jpeg format.
None is perfect.
To post an image : related links in the third announce of this page : viewforum.php?f=21
or viewtopic.php?f=21&t=52
or http://translate.google.com/translate?h ... php?t=1360
None is perfect.
