filtre studio x
filterprofi
Version de PhotoFiltre : 64
Système d'exploitation : win xp
filtre studio x
Message par filterprofi »
after good experience with "normal version" I tested today the studio version,
I tried to add some PNGDATA files ( *.png format) in corresponding catalogue....
I allways got an error message: "...file was not loaded " ??
which criteria have to be fullfilled to work as pngdata file ??
Thanks
Re: filtre studio x
==> when using what filer or function ?
wher did you copied the PNG ? only PNG format of course.
filterprofi
Re: filtre studio x
I copied my new *.png files ( 24 bit truecolor RGB ) to catalogue PNGDATA and tried to use them changing a picture with Filter > PHOTOPNG ...
thanks
Re: filtre studio x
can you post here a sample, i will test with it
Re: filtre studio x
The PNG file format must be as RGBA mode converted : menu Image/Mode/RGBA with alpha channel.
Re: filtre studio x
==> of course, forgot this "detail" :oops:
filterprofi
Re: filtre studio x
after changing "normal" RBG-PNG-Files to RGBA files
I am now able to fill PNGDATA catalogue with some additional personal files.
..... a hint how to use PNGDATA files (in PHOTOFILTRE.HTM) with the information that here RGBA Files ONLY are usable would be very helpful.
THANKS
filterprofi
Re: filtre studio x
I found TOOLS > Batchconverting
I used this tool to convert my data hopefully expecting that the output is usable for PNGDATA-files ... no success !
the output are obviously "normal" RGB PNG files.
Is it possible to add here an option for output of type RGBA - png- Files in next program version ??
Re: filtre studio x
not for the moment, the batch only support 24 bit
