SuE
Messages : 33 Inscription : 17 févr. 2005 20:37
Message
par SuE » 22 mars 2005 14:36
I found interesting program which can create random abstract pictures - great source for montages and backrounds - Knotplot.
It is math simulation program but as side effect, it generates pictures
I played with it for 1 hour and made some screenshots - you can see them here:
http://photofiltre.suewebik.net/galerie ... s/knotplot
If you are interested, go to the Knotplot page:
http://www.cs.ubc.ca/nest/imager/contri ... tPlot.html
and look at their pictures.
The program and the screenshots are free for non commercial use.
Download is here:
http://www.pims.math.ca/knotplot/download.html
The easiest way of getting pictures is through the Demo2 tab - just try buttons and you will see. look at the bottom panel for help - it offers function keys for another effects.
I made screenshots using alt+printscreen keys (to get only active window) and saved them in photofiltre as new image.
Messages : 2950 Inscription : 08 mars 2004 18:17
Version de PhotoFiltre : Dernières de PF Free et PFS
Système d'exploitation : Windows XP Home SP2
Processeur : Athlon 64 3500+ non O/C
Mémoire RAM : 2x512 Mo en DC
Message
par FrançoisL » 22 mars 2005 17:46
Fine
Thanks
Messages : 13312 Inscription : 02 févr. 2005 9:35
Message
par Tom » 22 mars 2005 18:42
Hi SuE,
Very good effects. It's nice.
Thanks for the gift.
I had tried a similar program : Chaoscope.
If you are interested you can find it at this adress :
http://www.btinternet.com/%7Endesprez/gallery.htm
Cheers
echo0001
Messages : 32 Inscription : 14 mars 2005 4:43
Version de PhotoFiltre : 6.1
Système d'exploitation : Windows 98
Mémoire RAM : 64mb
Message
par echo0001 » 23 mars 2005 9:22
Thanks for the information, and the links. It looks like it could be useful.
delphiuser
Messages : 173 Inscription : 06 oct. 2004 13:54
Version de PhotoFiltre : 6.0.2
Système d'exploitation : Windows XP Pro SP2
Processeur : PIII 1GHZ
Mémoire RAM : 128 Mo
Messages : 4298 Inscription : 13 nov. 2004 22:33
Version de PhotoFiltre : 6.53, 7.21, PFS 10.14.1, PF11
Système d'exploitation : Windows 10 Famille 64 bits
Processeur : Intel Core i5 3470
Mémoire RAM : 12 Go
Message
par Corwin13 » 23 mars 2005 13:48
Very interesting links, SuE and Tom! Thanks a lot!
Patrick
Adrien
Messages : 367 Inscription : 06 mars 2005 11:32
Système d'exploitation : Windows XP / Ubuntu
Mémoire RAM : 1GO
Message
par Adrien » 23 mars 2005 14:00
Superb! I adore these images!
themis
Messages : 10 Inscription : 15 mars 2005 14:32
Message
par themis » 23 mars 2005 14:59
EHHH EHHH EHHH
Eh ben vous voulez que je vous dise !
j'ai tout compris et j'ai même pas besoin de traduction
Mais peut être par contre que certains membres du forum la souhaiteraient...je ne sais pas
Adrien
Mémoire RAM : 1GO
Message
par Adrien » 23 mars 2005 15:05
C'est tellement facile
Mémoire RAM : 12 Go
Message
par Corwin13 » 23 mars 2005 16:08
@themis: Quand j'ai un problème de traduction, j'utilise volontiers reverso:
http://www.reverso.net/text_translation.asp
Sans être la panacée, ça permet d'avoir une idée de ce que dit le texte. Il suffit de faire un copier-coller du texte à traduire dans le premier cadre et de cliquer sur le langage approprié.
Patrick
armand
Messages : 4 Inscription : 05 avr. 2005 21:18
Message
par armand » 09 avr. 2005 23:04
Hey,
Very nice and........THANKS VERY mutch every body for that info. It help to start with this program
Armand
Erik Fou
Messages : 425 Inscription : 08 mai 2005 6:59
Version de PhotoFiltre : Studio
Système d'exploitation : XP
Processeur : ?
Mémoire RAM : 512
Message
par Erik Fou » 10 juin 2005 18:03
Je ne comprends pas l'anglais
Existe il une aide* en français
*(pdf, html, txt,...,...)
Merci d'avance
Message
par Tom » 10 juin 2005 18:15
Oui Erik,
On peut t'aider, à condition de nettoyer tes lunettes. C'est d'ailleurs ce que je vais aller faire avec les miennes.
Plus sérieusement tu remontes un peu dans le sujet et Corwin propose un outil de traduction.
Allez un peu de courage.
Erik Fou
Processeur : ?
Mémoire RAM : 512
Message
par Erik Fou » 10 juin 2005 18:35
Rebonjour
oui je suis un peu feignant
si il avait été tout prêt
plus facile
Bon ben courage il que
je m'y mette
A+
Erik Fou
Processeur : ?
Mémoire RAM : 512
Message
par Erik Fou » 10 juin 2005 18:53
PS: je parlais du logiciel
Knotplot
A+et Merci
