Does Photofiltre support CMYK?
pcwc66
Message par pcwc66 »
I want to split an image into CMYK images. How can I do that in Photofiltre?
Re: Does Photofiltre support CMYK?
PhotoFiltre does not support this colour format.
However you can instal a PDF virtual printer like "PDFCreator" and the settings of this soft allows you to convert the colours in CMYK.
This issue is agreed by the professionnal printers, when the image is converted in PDF with a resolution of 300 dpi.
http://www.pdfforge.fr/pdfcreator
cherry upon the cake : this virtual printer is usuable from any application and returns documents in a universal format,
which are readable by any contacts, (and not easy to modify).
