Trouble with the Startup Folder and other settings
Typhlosion
Version de PhotoFiltre : photofiltre 6.1
Système d'exploitation : Windows Vista
Message par Typhlosion »
Hi there!
I hope you can help me out. :evil:
I try my best to describe my problem as best as possible, since my english isn't the best...
It goes around the following problem:
Everytime I start Photofiltre, the settings switch back to standart I suppose.
If I want to open an image, it starts in the folder "Photofiltre" instead of the last visited folder.
So I went to "Tools -> Settings -> Folder" and choosed the desired Startup folder, as well as the storage folder.
It does not work. It only works for the current session, but when I restart photofiltre it's the same as at the beginning.
Same here, with the exception that the paths arw not saved even in the same session: I use the "Photomasque" and everytime I continue using the Photomasque in the SAME(!) session, the settings switch back to standart which is pretty annoying when I want to use the same pattern all the time. So I have to select a new pattern for each new opening of the photomasque-feature.
So I hope you understand my problem, I'm kinda clueless...I have an Computer with XP where it runs perfect, but on my Laptop with Vista it's just...
my sister has exactely the same problem.
I hope you can help me out a bit, seriously, I was asking the same question over and over again without getting ANY help...so please help me.
Re: Trouble with the Startup Folder and other settings
what is your photofiltre version ?
first, remove the photofiltre.ini file in your photofiltre folder and in the windows directory (if available, not sure)
Start photofiltre annd set your start folder
open the correct ini file in
'%APPDATA%\photofiltre\PhotoFiltre.ini'
and check the setting folder
Typhlosion
Mine is: Photofiltre 6.1
Yay, it worked, thank you so much!! I didn't expect it would be that simple!
Finally I can work without stress :clap:
Thanks again, you really helped me out :lol:
ok but it's better to download the 6.4 for Vista and windos 7 :wink:
