Framing of photos
Johan
Processeur : 3.2
Mémoire RAM : 2.0
Framing of photos
Message par Johan »
Hi, is there anybody that can help me with my problem? I need to frame a batch of photos at the same time ( I don’t have time to do it one by one) with the same frame how do I do this in Photofiltre? My Potofiltre is 6.2.5 :lol:
TX
JM
Re: Framing of photos
Hi Johan,
the current release of PhotoFiltre freeware is 6.4.0 : http://photofiltre.free.fr/download_en.htm
on the offical website : http://photofiltre.free.fr/frames_en.htm
To do frames on several pictures ( with similar output size) use the Automate/batch function :
menu Tools / Automate-Batch and look at the Image thumb.
The shareware version of Studio offers some advanced functions in the Automate/Batch module
for frames as a png layers which support 255 levels of transparency for any kind of tags, signatures, frames ...
Johan
Processeur : 3.2
Mémoire RAM : 2.0
Message par Johan »
Thanks Tom
But is there anyway i can do this in Photomasque?
PhotoMasque works fine but for one picture at a time, not as a batch process.
And the effects you get with PhotoMasque aren't the same as these you get with PNG module of Studio release.
Moreover the PNG module is included in the Automate/batch module of the Studio release.
Johan
Processeur : 3.2
Mémoire RAM : 2.0
Message par Johan »
Hi Tom
Done and got hold of Studio, beautiful but is there any way that I can import more PNG frames or mask?
I have tried but got the message that said no not a png file.
Or is there a plug-in?
Indeed, but if you remember the object : you would to play with transparency. :)
So your png file has to be defined and saved as a RGBA image : menu Image /Mode/RGBA (Alpha channel)
