pictures from computer??
mikesrob
- Version de PhotoFiltre : 6.4
- Système d'exploitation : vista s/p 2
- Processeur : D
- Mémoire RAM : 3 Gig
Hi, new to photofiltre, can I obtain pictures stored in the computer??, cant see this option, using version 6.4, thank you, Mike.
Re: pictures from computer??
Pictures are stored in the computer as recorded files.
The process to load some files in PhotoFiltre is the same as in all applications for Windows operating system.
Menu File / Open and set the correct path in the Open window.
But perhaps have i the question misunderstood ?
mikesrob
- Processeur : D
Hi, I have pictures stored in the computer, how do I open pictures already stored in the computer with photofiltre, I can only see an option to import pictures using scanner. the picture I want is in picture gallery ( vista ).Thank you.
Menu File / Open, or Ctrl + O
