Bad Photo
Jaume44
Système d'exploitation : w7
Bad Photo
Message par Jaume44 »
Photo taken at the Parade of Bands and Clubs of the Fallas of Alcira, Valencia in Spain, March 19, 2005. This photo came out blurry. Utilizing software from Antonio da Cruz, PhotoFiltre, improvements were made. The original was blurry, too blurry simply to use the sharpen tool. After cropping to the area, a radial mask was applied, then the sharpen tool followed by sandstone in the TEXTURE filter. Finally it was brightened in the adjustment tab, then back to the Filter tab to color, enhance color. The frame is executed with edit, stroke and fill stroke only. The fill was done by edit, selected from my files graphic, define pattern from personal selection mentioned, then fill pattern within the selected framed area. Nothing new, simply procedure to make a blurry photo more interesting.
Jack :roll:
Kamikaze
Mémoire RAM : 4T
Message par Kamikaze »
nice work :wink:
