Hi, and thanks for taking the time to read over my question.
Is there a way to resize the background only, midway through a project?
For instance, if I wanted to design a flier, then discover I needed to add more room at the bottom to finish, do I have the ability to increase the size of the background itself, (widen / or lengthen) rather than "copy merged" then paste onto a new resized background?
Using PF Studio 10.2.0
Thanks,
b1rd
Background Resize Question
b1rd
- Version de PhotoFiltre : 6.2.3/ PF Studio
- Système d'exploitation : Windows XP Home
- Processeur : Intel
- Mémoire RAM : 3Gigs
Re: Background Resize Question
Hi bird,
i'm not sure to understand correctly the question
- Take a white sheet, draw a rectangular selection and right clic in the selection / Duplicate
- fill the layer with a red color, right clic on the layer thumbnail / Manual settings and note the size values of the layer.
- right clic in the image / Canvas size and modify seriously the values and validate
You can verify that the red layer keeps his size.
Have i mess something ?
b1rd
Let me see if I can clear it up so it makes sense.
Let's say I'm doing a flier. I'm using a white background.
I add a title with some effects, which is the first layer. I add some additional text, which is layer number two. I add an image, then another, so by now there 4-5 layers. At this point I realize I need more length added to the project because I misjudged the canvas size (background).
What I would do is to create another blank project (background) and increase the canvas, then "copy merged" and paste that to the new canvas, for the needed room.
I was wondering if there was a way to merely increase the size of the background, keeping the other layers in tact on that same project?
I don't know where is any matter ?
Why not use right click / Canvas size ?
Try it and say possibly what doesn't match.
b1rd
OK, I'm an idiotWhy not use right click / Canvas size ?
That was it. I had been trying that via the right pane (background) layer. I never thought to try right clicking and changing the canvas that way, as I figured it would increase everything along with it.
Problem solved and this will save me lots of time, as I often mis-judge the needed size, as I do these from scratch.
Thanks again Tom!
You can see how it's easy to be prisoner in his own ways.
that is the case for "Image size" function, but not for "Canvas size"
