Sticky mouse pointer in Photo Filtre
selkie305
Version de PhotoFiltre : 9
Processeur : Intel Pentium
Mémoire RAM : DDR2 800 2G+2G
Message par selkie305 »
Hi, I am using the most recent version of Photo Filtre on a notebook, with a trackpad, Windows 7. The mouse pointer sticks and moves erratically at times. This happens mostly with Photo Filtre, not usually when I am on other programs or applications. Would this be corrected if I use an external mouse? And is there any type of mouse that is best for fine control of movement? Thank you.
Re: Sticky mouse pointer in Photo Filtre
I don't use special function with PhotoFiltre, it's sandard mouse windows function, not other function. Mouse event can be setting using windows control panel paramters, not a PhotoFiltre special setting :wink:
selkie305
Thank you. Can someone please clarify this answer for me? :roll:
Hi,
you should adjust the settings for your mouse (or trackpad) in the Microsoft Windows tools of the operating system.
PhotoFiltre has no settings for that.
An optical lazer mouse is generaly more precise than a trackpad, and more heavy it can be, more precise is the mouse.
selkie305
I've already adjusted the mouse settings. It seems like a compatibility thing between the laptop and Photo Filtre. I will try an external mouse. Thanks!
