Hi,
I usually take pictures the size of 3648 x 2736.
And I resize these pictures before uploading blog.
Resize unit is 5%.
If the number of pictures is a low, about under 5 from 10, I use to resize Image > Image size > New size manually.
But, a lot of number of pictures, about over 20 or more, I use to resize Tools > Automate / Batch.
The problem occurs there.
Automate / Batch > Image tab >
setting,
-Image size checked
-Unit % selected
-Width, Height 5% inputed
then go to Action tab, Image size setting changed automatically 10%.
And Ok click, pictures 10% resized.
I'd like to resize 5% using Automate / Batch.
Thanks
How to resize under 10% unit using Automate / Batch process?
RC3
- Version de PhotoFiltre : 6.4.0
- Système d'exploitation : XP SP3
- Processeur : Celeron 1.1GHz
- Mémoire RAM : 1GB
Re: How to resize under 10% unit using Automate / Batch process?
use limit values in pixels for more precision
RC3
- Mémoire RAM : 1GB
Thank you.
I didn't have such idea.
It was possible to do when executing it.
Thank you really
Thank you really
