Help, I'm frozen! ESC doesn't even work :(
mzart
Version de PhotoFiltre : ? English ?
Processeur : AMD (Vision?)
Mémoire RAM : 215 GB
Message par mzart »
I was almost finished with a project and pasted in a new layer. I couldn't move the layer so I tried Transform > Redim (?) and nothing happened. I remembered to Enter before proceeding but that didn't help. ESC doesn't work, and I don't get a Popup Menu. I can't close the two files I have open and I can't close the program (always get the error box that says must end current transformation before continuing. But I can't!
I probably should have purged the histories and clipboard, shouldn't I? (Now I can't use any thing in the task bar except Zoom)
Maybe I should close my browser?
I don't want to lose this project!!!
I've only had the program 21 days; still learning where everything is. I like it a lot so far. Posted about it on my blog. I hope to buy the registration.
Thanks very much!
Alisa
----using Windows7
Jaume44
Système d'exploitation : w7
Re: Help, I'm frozen! ESC doesn't even work :(
Message par Jaume44 »
I am not expert, however this has occurred in the past with me. It turned out I had a window open in PFS, but somehow it became hidden behind the main PFS window. By depressing alt plus tab the culprit became visible, and I was able to act upon the hidden window. J.....
I think your version is the V6 freeware and this version don't support layers :wink:
After validation with Enter you can not move it again
Only the Studio X support layers...
mzart
Message par mzart »
Thanks for your replies!
Jaume44, I shut down my computer, forcing PF to close, before I saw your idea to try Alt+Tab.
Antonio, I'm using the trial version of PFStudioX (10.2.1) with Windows 7 and the layers worked before.
I have only 7 days left for the trial. For some reason, the English version keeps getting "lost" and my grasp of French is terrible :oops: I haven't had a lot of time to figure it all out. I need another 30 days ;)
Alisa :)
don't forget to move a layer, you must select the layer tool in the right tool bar :wink:
(or key W)
mzart
Message par mzart »
Antonio, I had been able to move layers easily before the freeze-up.
Since I can't find the English version of PFSX on my computer again :( I tried my project with another program and a similar thing happened (program freezing and closing down). So I'm thinking it must be a memory problem (?)
I need to find the preference to save files often. As I said, I'm still finding my way around.
Thanks again for replying!
Alisa
