samsung aio printer problem
sartic
Version de PhotoFiltre : 6.4
Système d'exploitation : ubuntu (virtual xp)
Processeur : amd x2
Mémoire RAM : 2GB
Message par sartic »
I have png file optimized for 600dpi for printing my visit card. First time I have this problem, when i preview print I have garbage and when I print .... I have empty page. When I print same page from XP wizard print preview and print is perfect. Printer is Samsung AiO. Printer problem? PF is free one.
Re: samsung aio printer problem
Hi,
i don't understand what you call "when i preview print". :shock:
There is no function for preview in the print window of PhotoFiltre.
Have you seen there is a setup button in the print window ?
It allows you to select the printer .
Under XP or Vista, never seen such problem but perhaps is it a GUI problem under Ubuntu ?
After close and reload have you still this problem ?
sartic
Processeur : amd x2
Mémoire RAM : 2GB
no it isn't my system. it had xp sp3. print preview is what you see before hit ok ;)
I think we are not talking about the same functions.
Here we are on the PhotoFiltre's forum Ok ?
The Print window of PhotoFiltre does not show any button for preview.
Can you precise how do you proceed to use a preview function ?
IonaTerry
Message par IonaTerry »
sartic a écrit :no it isn't my system. it had xp sp3. print preview is what you see before hit ok ;)
Are you sure about this. :O I am surprised
sartic
Processeur : amd x2
Mémoire RAM : 2GB
100%, i am suprised about you.
