EXIF bug in PF Studio 10.1.0 (as spotted by Exiv2-0.19)
Silversleeves
Version de PhotoFiltre : Studio X 10.2.0
Système d'exploitation : Windows XP SP3
Processeur : Intel vPro Dual 1.8G
Mémoire RAM : 1 GB
Message par Silversleeves »
Almost inevitably, when PhotoFiltre 10.1.0 saves a new JPEG file, and I use exiv2 on the command-line to read back the data, it looks something like the following.
Code : Tout sélectionner
Error: Directory Image: Next pointer is out of bounds; ignored.
Error: Directory Photo: IFD exceeds data buffer, cannot read next pointer.
pont-0-neuf.jpg       Exif.Image.Orientation                       Short       1  top, left
pont-0-neuf.jpg       Exif.Image.XResolution                       Rational    1  72
pont-0-neuf.jpg       Exif.Image.YResolution                       Rational    1  72
pont-0-neuf.jpg       Exif.Image.ResolutionUnit                    Short       1  inch
pont-0-neuf.jpg       Exif.Image.Software                          Ascii      21  PhotoFiltre Studio X
pont-0-neuf.jpg       Exif.Image.DateTime                          Ascii      20  2010:02:18 10:28:57
pont-0-neuf.jpg       Exif.Image.ExifTag                           Long        1  155
pont-0-neuf.jpg       Exif.Photo.ExifVersion                       Undefined   4  2.10
pont-0-neuf.jpg       Exif.Photo.PixelXDimension                   Short       1  576
pont-0-neuf.jpg       Exif.Photo.PixelYDimension                   Short       1  432
The first two lines also appear whenever I use the same exiv2 to write or delete EXIF or IPTC data to or from a JPEG file created in PhotoFiltre Studio 10.1.0.
Has this issue been addressed and fixed in a later version (that is, should I upgrade)? Or is this the first anyone's heard of PFS putting pointers "out of bounds" and not quite following the rules for IFD?
BZT
Re: EXIF bug in PF Studio 10.1.0 (as spotted by Exiv2-0.19)
For the moment this bug is not known. But i don't understand why when you remove the Exif data, The first two lines also appear.
Did you try to remove with other soft like XnView or other ?
Silversleeves
Mémoire RAM : 1 GB
Antonio a écrit :For the moment this bug is not known. But i don't understand why when you remove the Exif data, The first two lines also appear.
Antonio,
Thanks for the quick reply. Answering your questions in order;
* I think it's in how Exiv2 works. It must load the tags as they are in the file in its current state, which would give the same error as the -p (print existing) option, then after a "wipe" (deletion), the errors disappear along with the tags, which of course returns no errors.
* No, I hadn't. I've got XnView, plus a freeware EXIF tag eraser (that's all it does; I'm sure you've seen ones like it). I think a lot of the GUI image editors are quite "forgiving" when it comes to exif data that might be a "little off the standard." Even Photoshop only complains if the color scheme is wrong or unavailable -- or if the file image data is incomplete, but that's a whole other issue. I have yet to get these errors in XnView or (returning to the command line) Phil Harvey's Exiftools, and I think the latter has some of whatever the GUI apps do to ignore or suppress such errors.
I think I might try an upgrade to 10.2.1 or newer. The worst thing that can happen is that it won't even write an EXIF Software tag.
BZT
Weyoun
Version de PhotoFiltre : 10.3.0
Processeur : Intel Core2Quad Q9400
Mémoire RAM : 4 GiB
Message par Weyoun »
First, my Name is Jürgen, i'm a 27 year old guy from germany. I'm using the free Version PhotoFiltre now for many years. Last year i decided to purchase a license key for PhotoFiltre, and i don't have any regrets. It's a great program and i love it. Thx to everyone who are responsible for it.
And now to my question. I think i found a bug in PhotoFiltre. It has to do with the EXIF-Data. If you save a picture and mark the "Save EXIF-Data" check-mark it should save the original EXIF-Data of the camera, right? I'm not sure, but i think with the free version this was no problem. But now with PF-Studio this function doesn't work any more. The EXIF-Data is getting lost, if you save a picture that you worked on. Is this an already known bug?
Here's my System:
Windows 7, Core2Quad Q9400, 4 GiB Ram
Sorry if that problem was reported earlier. I searched the Forum and the only thread in english i found, was this one. I don't speak french. :)
Silversleeves
Mémoire RAM : 1 GB
In PhotoFiltre Studio version 10.2.1 the problem of mislaid markers persists but seems to be limited to images one creates in PFS, as by way of a cut & paste from a browser or another image application, and saves to disk, not any that one opens from any media.
@Jürgen: PF Studio migrated this to Options:Saving, where you set your default save file format and tell the application whether or not you want the original creation/modification dates preserved on save. Clicking in the next check-box down from that (and clicking on OK) tells PF Studio to look in any file that supports them for EXIF and/or IPTC data, and if it finds any, you'll see the "Save Exif/IPTC data" check-box again in the Settings dialog box when you save the file. From there you can choose whether to do so in a specific file or not, as you probably did with the freeware PhotoFiltre.
BZT
Silversleeves
Mémoire RAM : 1 GB
Just to let you folks know, the bug persists. No I have not checked for updates to PF Studio X since April, but it would make little sense for me to do so unless I was somehow made aware that an effort had been made at correcting this problem. To put the best possible face forward on this issue, I'm including output from a command-line utility other than Exiv2: ImageMagick.
Two files that showed the error in the former application just this morning had output data that looked like:
ImageMagick info
	Image: gae68-6860-032-004bath.jpg
  Format: JPEG (Joint Photographic Experts Group JFIF format)
  Class: DirectClass
  Geometry: 492x745+0+0
  Resolution: 72x72
  Print size: 6.83333x10.3472
  Units: PixelsPerInch
  Type: TrueColor
  Endianess: Undefined
  Colorspace: RGB
  Depth: 8-bit
  Channel depth:
    red: 8-bit
    green: 8-bit
    blue: 8-bit
  Channel statistics:
    red:
      min: 5 (0.0196078)
      max: 255 (1)
      mean: 182.261 (0.714749)
      standard deviation: 60.178 (0.235992)
    green:
      min: 12 (0.0470588)
      max: 249 (0.976471)
      mean: 160.888 (0.630934)
      standard deviation: 69.0387 (0.27074)
    blue:
      min: 0 (0)
      max: 249 (0.976471)
      mean: 146.142 (0.573105)
      standard deviation: 81.7046 (0.32041)
  Rendering intent: Undefined
  Interlace: None
  Background color: white
  Border color: rgb(223,223,223)
  Matte color: grey74
  Transparent color: black
  Page geometry: 492x745+0+0
  Dispose: Undefined
  Iterations: 0
  Compression: JPEG
  Quality: 81
  Orientation: TopLeft
  Properties:
    create-date: 2010-07-31T04:24:11-04:00
    exif:DateTime: 2010:07:30 17:58:30
    exif:ExifImageLength: 745
    exif:ExifImageWidth: 492
    exif:ExifOffset: 122
    exif:ExifVersion: 0210
    exif:Orientation: 1
    exif:ResolutionUnit: 2
    exif:XResolution: 72/1
    exif:YResolution: 72/1
    jpeg:colorspace: 2
    jpeg:sampling-factor: 2x2,1x1,1x1
    modify-date: 2010-07-31T04:24:11-04:00
    signature: d52de37db904ee3d45b9622a4f837db040d04aeba73640f7df200f3b8f0304a9
  Profiles:
    Profile-8bim: 44 bytes
    Category[2,15]: PRN
    Credit[2,110]: Adult Empire sites
    Profile-exif: 170 bytes
  Artifacts:
    verbose: true
  Tainted: False
  Filesize: 42.5703kb
  Number pixels: 357.949kb
Exiv2 0.19.1 Error message:
And...
ImageMagick info:
	Image: rva-089-012-4-pat2.jpg
  Class: DirectClass
  Geometry: 256x320+0+0
  Resolution: 72x72
  Print size: 3.55556x4.44444
  Type: TrueColor
  Colorspace: RGB
  Depth: 8-bit
  Channel depth:
    red: 8-bit
    green: 8-bit
    blue: 8-bit
  Channel statistics:
    red:
      min: 19 (0.0745098)
      max: 255 (1)
      mean: 229.159 (0.898662)
      standard deviation: 45.9802 (0.180314)
    green:
      min: 8 (0.0313725)
      max: 255 (1)
      mean: 216.398 (0.848619)
      standard deviation: 61.6198 (0.241646)
    blue:
      min: 2 (0.00784314)
      max: 255 (1)
      mean: 210.705 (0.826295)
      standard deviation: 69.6176 (0.27301)
  Interlace: None
  Matte color: grey74
  Page geometry: 256x320+0+0
  Dispose: Undefined
  Iterations: 0
  Compression: JPEG
  Quality: 91
  Properties:
    create-date: 2010-07-31T04:24:15-04:00
    exif:DateTime: 2010:07:31 00:21:47
    exif:ExifImageLength: 320
    exif:ExifImageWidth: 256
    exif:Orientation: 1
    jpeg:colorspace: 2
    modify-date: 2010-07-31T04:24:15-04:00
    signature: aabae78826bde09298ae1af70928f58e0409c5df8978752a71cd6b834f8003ce
  Profiles:
  Artifacts:
    verbose: true
  Tainted: False
  Filesize: 12.7402kb
  Number pixels: 80kb
The full text-file printout is available here for your perusal.
BZT
possible, i use dExif for DElphi but this lib is not supported now :cry:
Silversleeves
Mémoire RAM : 1 GB
Exiv2 "ain't the only one complaining."
Seems appropriate I'd have already posted dumps and outputs from ImageMagick.
One of its supporting tools, jhead, also throws an error when you use its "-purejpg" option ( similar to Exiv2's '-da' -- delete all metadata -- or Exiftools '-all' ). The error I saw follows:
Nonfatal Error : 'bv0856-250.jpg' Illegal subdirectory link in Exif header
Maybe this gives someone a clue as to where/how to start re-coding the software "stamp" in the EXIF of supporting files.
BZT
