Possiblity to have image explorer ON by default...
kris
Message par kris »
Hi!
I'm new to photofiltre. It's great!!
Is it possible to have image explorer ON by default??
(I didn't find any option....).
If not, this would be a great addition :D :idea:
regards
kris
I think this should be a good improvment, yes :)
Now wait for Antono's answer...
You can use F5 to show and refresh explorer. If i set the explorer by defaut, i need to load thumbs too and this is very slow and not recommended at startut. I like that PhotoFiltre load less than 1 second :wink:
