Can somebody tell me how to increase change the resolution, without have the image increase in size.
I'm trying to make a 5.47 x 4.21 postcard for a friend and it need to be 300 DPI. When I increase the DPI to that size, the entire image is huge. I am able to reduce it, but will it still be at 300 DPI, even though it says so?
Also, is there a way to merely increase the DPI to the amount without having to go back and reduce it?
I'm using both PF and PF Studio
Thanks
B1rd
Resolution Question
b1rd
- Version de PhotoFiltre : 6.2.3/ PF Studio
- Système d'exploitation : Windows XP Home
- Processeur : Intel
- Mémoire RAM : 3Gigs
Re: Resolution Question
Set first the resolution value when the unit size is in pixels, (the size does not change)
and next change the unit size to enter the target size in inch,
and ou can see the size does not increase, on the contrary.
b1rd
Tom, thanks again. That seems to do the trick.
Take-care-
b1rd
Take-care-
b1rd
Fine bird and thanks, i have so learn several idioms about one post, while you discover the tricks of the trade.
