Hi, I would like to obtain a banner with a frame like the central banner at this link:
http://www.friuladria.it/jsp/it/index/index.jsp
if you see the banner when it's changing, you will see a frame with a very thin line and with the round border.
I try with the last version of Photofiltre to make this with set shape/round rectangle but it's not possible to adjust the corner of the round and the line is too large also with width "1".
Can you help me?
Thanks,
Alex
Border - Contour - Frame
debelik
Re: Border - Contour - Frame
Hi debelik,
you can try this link with an automatic translation :
http://translate.google.com/translate?h ... 39#p117539
debelik
Thank you very much Tom.
A last question: I use the selection shape-->round rectangle for my banners and I find very well with this tool. Is it possible to arrange the corners radius of the round rectangle? Or is it possible to create a new shape after create it as explaned in the link you have posted (http://translate.google.com/translate?h ... 39#p117539)?
Thanks again for you help,
Alex
Alex
I'm not sure that Antonio wishes change anything about this tool,
but yes you can save a new shape with which one you have created.
debelik
...and how can I save the new shape? (it is a .pfs file)
