Found some interesting pics to make patterns from .. will be adding more in the next few days, i'm sure.
Check them out at link below:
http://www.4shared.com/dir/29361575/df4 ... terns.html
Enjoy
Abstract Patterns to use with Photomasque
Mask_man
- Version de PhotoFiltre : 6.4
- Processeur : Dell
- Mémoire RAM : 1 GB
Mask_man
- Processeur : Dell
Re: Abstract Patterns to use with Photomasque
Ever expanding patterns .. 24 and counting.
I find shapes / patterns and other items that interest me, edit, upload, then let you decide.
Check them out below:
Enjoy
Enjoy
Hi Mask-man,
it would be easier for the other users if you could enter the right BBcode tags for the links,
or uncheck in your personnal Profile / Edit signature : Do not automatically parse URLs
Thanks
Thanks
Mask_man
- Processeur : Dell
Thought I had .. thanks for the info.
http://www.4shared.com/dir/29361575/df4312f7/Photomasque_abstract_patterns.html
