Hello Antonio, I love your tools!! I have been looking for a smart small graphic tool, and I was using GIMP up 'til now. But sometimes it is toooo big for quick work, with the right quality - and that is what PhotoFiltre is.
Hello all,
sometimes I need a circular gauss effect. This is useful for creating motion in rotating objects.
I am useless in creating plug-ins, therefore sorry not creating one, but my thought is to include GIMP plug-ins into the PhotoFiltre.
I have seen many discussions on Photoshop Plugins, but as there might be the problem getting the correct source code, this should be no problem or?
Circular Gauss effect - GIMP plug-ins
DMD
- Version de PhotoFiltre : 6.4
- Système d'exploitation : Win7
- Processeur : Intel Dual Core 3Ghz
- Mémoire RAM : 6 Gbyte
Re: Circular Gauss effect - GIMP plug-ins
No problem for the idea, what did you need ?
photofiltre source can be find on the linux projetct site : http://www.photofiltre-lx.org/
