I'm new to this software, and would like some suggestion.
Mundo
- Version de PhotoFiltre : trial version
- Système d'exploitation : xp
- Mémoire RAM : 4g
Hi I'm Mundo..I just downloaded this software and I love it...but unfortunate I need to familiarize myself with the tools, I printed out some manuals and tuts..hope that will help, any suggestion for a newbie?
Re: I'm new to this software, and would like some suggestion.
Hi Mundo, welcome on this forum,
If you have found some manuals and tutorials, you are on the right way.
Try and check the different tools and come back to submit your particular questions.
Read you soon.
Read you soon.
Doug Bays
- Version de PhotoFiltre : 6.3.1 and 9.2.2
- Système d'exploitation : Windows XP Pro SP2+
- Processeur : Intel Dual Core 2666
- Mémoire RAM : 2048
The software has the easiest learning curve of anything available at any price. If you're completely new to photo editing, contact me by e-mail as I've done a short "get started" tutorial for others, covering the absolute basics. < xxxxxxxxxxxxxxxxxxxx>.
You might also add some information as to your computer, photographic and any editing knowledge you may have.
For instance, do you know how to "load an image into PhotoFiltre"... the difference between "Save and Save as" etc.
May sound ridiculous to you, but the majority of digital camera owners have little or no basic photographic knowledge, and even less about editing.
It's just much easier to provide information when one has an rough starting point.
Doug Bays
[Tom] no direct mail adress, ther is a specific tool in your profile [/Tom]
Doug Bays
But if you can propose some tutorials, why are they not visible on your web site ?
The link of your profile returns an error.
