How do I add a direction arrow with text to a captured pict
Janset
Système d'exploitation : XP Pro SP3
Processeur : Intel Pen 4
Mémoire RAM : 1Gig
Message par Janset »
Hi all.
I am a Newbie on this forum so I hope I am doing the right thing.
I have a web picture captured and saved to me desktop. To this picture I would like to add a colored (pointing) arrow with the words, "click here".
How would I go about doing this? :(
Regards
Re: How do I add a direction arrow with text to a captured pict
Use the Line tool (in the tool palette) and check the option arrow
Janset
Mémoire RAM : 1Gig
Thanks for that Antonio. I will check it out the next time I play around with it. If I find difficulties I'll call back. :)
Regards
