copy clipboard bug and maybe new bug in 6.4
sartic
Version de PhotoFiltre : 6.4
Système d'exploitation : ubuntu (virtual xp)
Processeur : amd x2
Mémoire RAM : 2GB
Message par sartic »
Free version not studio one. When u copy select image in browser example and paste it in PF 2 or more pixels vertically r shift left and they appear on right of pasted picture. Even last version didn't resolved this bug. I have a new problem in PF 6.4 also. When i zoom picture above 100% i have image in real size all other is empty space. I will try new nvidia driver.
Re: copy clipboard bug and maybe new bug in 6.4
==> i don't changed display function, then i don't think it's a special bug for the 6.4, i think this problem allready exits with the previous version.
On my PC i have not this bug...other users have this bug ?
Yes it hapends the same behaviour in PF6 or even PFSX, when the Windows clipboard is tired.
Generaly when i close and re-open the software, this shift disappears.
sartic
Processeur : amd x2
Mémoire RAM : 2GB
I restarted this machine, didn't apply new driver yet. It had long uptime, now zoom works. Didn't know that PF is so sensitive to resources. This XP machine has few win32 server running 24h. I am still using PF even under wine (i am faster width it than GIMP) for some multiple same jobs.
of course PF is sensitive to resources because PF use windows api function to display and stretch image and for lot of other :wink:
sartic
Processeur : amd x2
Mémoire RAM : 2GB
Never had that problem before (resources). Copy bug is for same reasons?
don't know, send me a screenshot of the bvug to uderstand :wink:
(you can run the windows clipboard viewer to test if the problem is when coping or when pasting)
sartic
Processeur : amd x2
Mémoire RAM : 2GB
sartic
Processeur : amd x2
Mémoire RAM : 2GB
PF is problem, Paint & GIMP are working perfect.
sartic
Processeur : amd x2
Mémoire RAM : 2GB
Tom a écrit :Yes it hapends the same behaviour in PF6 or even PFSX, when the Windows clipboard is tired.
what's your graphic and driver version?
Two different stations : same problem => its not a graphic card or drivers problem
I'm not sure it's a photofiltre bug. I think this pixels are used to add some information like alpha blend or transparency and must be ignored when pasting, but photofiltre don't know this format and don't clip it :wink:
What is your browser, i tested with firefox with no bug...
sartic
Processeur : amd x2
Mémoire RAM : 2GB
same machine and opera has same problem.
I have just tried again with Firefox and i get a bug in PFStudio and not in The Gimp.
