When using text (T), some romanian diacritics are not supported.
I can write into the box, but then I press OK, not all are shown.
Here is the result:
http://img524.imageshack.us/img524/3176/diacritice.png
Any help ? Thank you.
romanian diacritics
- Version de PhotoFiltre : 6.3.2
- Système d'exploitation : Windows XP SP3
- Mémoire RAM : 1 GB
Re: romanian diacritics
can you test with the basic photofiltre V6 ?
The same result with PhotoFiltre 6.3.2 or Photofiltre Studio X 10.2.0
http://img21.imageshack.us/img21/6384/diacr2.png
In this case, the problem is that Delphi 7 don't support unicode 16 bit. Only text in 8 bit and your police works only in 16 bits
I will try ti fix this oin futur version but for the moment it's not supported
