can i remove white sky and copy in blue sky
simon333
Version de PhotoFiltre : latest free version
Processeur : 2.4
Mémoire RAM : 1 gb
Message par simon333 »
is there an easy to understand way of removing boring white sky and putting in its place blue sky with clouds, i have a picture i could use as a donor sky, thanks in advance for any advice given.
Re: can i remove white sky and copy in blue sky
Hi Simon,
Just for information : you can get any translation about available tutorials by this way :
viewtopic.php?f=21&t=14191
And for your demand it matches like that :
http://translate.google.com/translate?h ... /ciel3.htm
So you can read any tutorials of this rather well-rounded list :
http://translate.google.com/translate?h ... stuto.html
simon333
Processeur : 2.4
Mémoire RAM : 1 gb
thanks tom, i seem to have been looking at another more basic tuturial some where on this site.
Near all they are here :
On the page, do Ctrl +F and type sky
You should find : http://translate.googleusercontent.com/ ... OWETMR0sIw
and others i think...
simon333
Processeur : 2.4
Mémoire RAM : 1 gb
thanks again tom.
simon333
Processeur : 2.4
Mémoire RAM : 1 gb
change sky not working
after down loading instructions on how to change a sky..... in EDIT i cant find "paste as picture", also in SELECTION i dont have "smooth", im using the free version..... if i have two pictures side by side could i copy and paste from one picture to the other, or could i clone from one picture to the other. simon.
Yes, you are using an automatic translation ... so you have to adapt to the context :
=> paste as picture = paste as new image
=> in Selection menu smooth = antialias
Try the both, and make your own opinion as the quick or best way to do.
simon333
Processeur : 2.4
Mémoire RAM : 1 gb
thanks tom, i didnt think about differences due to automatic translation
