Picasa to PhotoFiltre button
RickS
- Système d'exploitation : WinXP
- Mémoire RAM : 512
Picasa allows the installation of custom "buttons" as shortcuts to open other programs, typically another editing program. I have seen buttons available for such programs as PhotoShop, GIMP, and Paint Shop Pro, but not PhotoFiltre. Does anyone know if a shortcut button for PhotoFiltre exists, or could someone with the necessary skills write one? Thanks.
Silversleeves
- Version de PhotoFiltre : Studio X 10.2.0
- Système d'exploitation : Windows XP SP3
- Processeur : Intel vPro Dual 1.8G
- Mémoire RAM : 1 GB
Re: Picasa to PhotoFiltre button
I suggest approaching this idea from both ends. I don't want to presume you have. Did you happen to post the same or a similar suggestion to the Picasa list or group on Google? You're more likely to find "someone with the necessary skills" there than here.RickS a écrit :Picasa allows the installation of custom "buttons" as shortcuts to open other programs, typically another editing program. I have seen buttons available for such programs as PhotoShop, GIMP, and Paint Shop Pro, but not PhotoFiltre. Does anyone know if a shortcut button for PhotoFiltre exists, or could someone with the necessary skills write one? Thanks.
BZT
jbarr
You would likely need to have a programming background, but here is a page detailing Google's Picasa Button API:
http://code.google.com/apis/picasa/docs/button_api.html
If I get around to digging, I may give this a shot, but I make no guarantees....
jbarr
OK, I coded a button to launch PhotoFiltre Studio X from within Picasa 3. You can find information about it here: http://jimstips.com/picasa2photofiltre
Currently, this ONLY works on the PAID version, "PhotoFiltre Studio X". if there are enough requests, I'll consider making a button for the Freeware version, however I highly suggest that you get the Studio version. It's extremely powerful and very inexpensive.
Have fun!
-Jim Barr
JimsTips.com
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Have fun!
-Jim Barr
JimsTips.com
RickS
- Mémoire RAM : 512
A belated "thank you!!", jbarr. Very much appreciated.OK, I coded a button to launch PhotoFiltre Studio X from within Picasa 3. You can find information about it here: http://jimstips.com/picasa2photofiltre
