Hi
Look at this record.
http://www.mldgroup.com/photofiltre/chyba.swf
You can see my mouse clicks.
I cant select points. All you can see on video.
Matej
Selection Tool bug
Matej
- Version de PhotoFiltre : 10.1.0
- Processeur : Intel Dual Core 2,66
- Mémoire RAM : 2GB 800 MHz
Re: Selection Tool bug
Hi,
if you increase the speed settings between two clicks to get a double click effect, you get the right issue.
When the level of speed is too low, two successive clicks can easily be understood as a double click = close the selection.
Matej
You are wrong.
Test it.
Create small object and zoom it. Then use that selection tool. And try to go like this algorithm
x=x+1;y=y+1
x=x+1;y=y+1
x=x+1;y=y+1
and somewhere here is error because it will do
x=x+2;y=y+1 and not x=x+1;y=y+1
This video has only 8 fps (created small size) and you didnt see all clicks.
I cant click there and select that point.
how it works
right function: x=x+1
and it do: x=x+2
Test it.
x=x+1;y=y+1
x=x+1;y=y+1
x=x+1;y=y+1
how it works
and it do: x=x+2
the selection autoclose when the current mouse pointer is near to the first selection point.
I think in your case the image is too small and all points are too near
Matej
Yes, you have right.
Can you fix it?
I need sometimes exactly images crop. This tool or function is important for me
Can you fix it?
Matej
How can I make undo or redo function when I am using this tool?
It is important too
Note this for new release
It is important too
no undo for the moment for the selction
try to use the lasso tool, not the polygon, the lasso don't autoclose, and for small selection it's better i think
