Option: Always show "Image explorer" bar
applaudmedia
Version de PhotoFiltre : 10.2
Système d'exploitation : XP Pro
Processeur : AMD Phenom
Mémoire RAM : 2G
Message par applaudmedia »
I'd like to request an option to always show the "Image explorer" bar with an option to set the default view (Current image folder, Opening folder, Masks, etc.).
Sorry if this has already been suggested. I searched to see if this had already been suggested but didn't find it (in English anyway).
I really enjoy using PhotoFiltre. It loads much quicker than all my other graphics editors so I use it a lot for basic editing, touch-up, resizing, etc. and it is quite a powerful application. Good Job PF Team!
Re: Option: Always show "Image explorer" bar
ypu can use the key "F5" to show the explorer and refresh the last folder :wink:
applaudmedia
Mémoire RAM : 2G
Thanks Antonio, that's a great tip!
However, I still think the option to always have it show a user selected folder would be an easy and useful tweak.
But then I'm very lazy, I write batch files like x.bat that simply type "exit" ;-)
Thanks again!
-Troy
