Save as CMYK
J Trahair
- Version de PhotoFiltre : 6.3.2
- Système d'exploitation : XP5.1 SP3
- Mémoire RAM : 1G
Save as CMYK
How can I save my image in the CMYK colour range? Thank you.
Re: Save as CMYK
not supported
Re: Save as CMYK
An other way is available :
You can use a virtual printer like PDFCreator : http://sourceforge.net/projects/pdfcreator/
This free software converts a copy of any file in pdf format, and in the options you can define resolution
and colors range mode.
When PDFCreator installed and options checked, open the file in PhotoFiltre and print by choosing PDFCreator as the printer.
This way was approved by a printing office of mine for a CD publishing.
