Reflection
Matej
Version de PhotoFiltre : 10.1.0
Processeur : Intel Dual Core 2,66
Mémoire RAM : 2GB 800 MHz
Reflection
Message par Matej »
Hi all and Tom :D
How can I create reflection effect (no Lake reflection).
Controlled reflection effect (e.g. MS Office Word picture reflection but with more options).
Thanks
Matej
Re: Reflection
Observ and you will understand how. :)
viewtopic.php?p=36348#p36348
Matej
Re: Reflection
Message par Matej »
Do you mean manual settings? Like this?
Source:
http://www.mldgroup.com/photofiltre/reflection.pfi
Re: Reflection
Fine :)
I think you are on the right way. The first and the third one are correct, and if you select and crop the reflect layer :
menu Layer / Transparency / Transparent gradient / Top to bottom
you can also decrease the text opacity from back to front.
For the second one, the function used does not write on the transparency, so you have to blend the text with a white layer before.
Same way to work with the : menu Filter / Deform / Trapezoid / Perspective.
With menu Layer / Transform / Distort , you don't need to use a blend with a white layer.
Matej
Re: Reflection
Message par Matej »
Update
Better reflection :shock:
Source:
http://www.mldgroup.com/photofiltre/reflectionv01.pfi
For better performance need change font.
Matej
Re: Reflection
Message par Matej »
Source:
http://www.mldgroup.com/photofiltre/reflectionv02.pfi
Deformation process is not correct. Antonio, improve deformation process :-)
letters c, e, s, and t are UP
and some letters/image are moved to right.
