Important Icons such as Clone Stamp Tool are hidden!!
mrguy
Système d'exploitation : win XP home
Processeur : x86 intel 1592mhz
Mémoire RAM : 512MB
Message par mrguy »
I've used photofiltre for years now and love- but suddenly I can't use it because the tool bar is messed up!
The icons are unusable simply because the window containing them (the tool pallet) will not expand to allow them to be seen. The blur, smudge, and clone stamp (the most important) are hidden.
what can I do? I've uninstalled and installed lots of times- tried different versions and every time I open it up to see, it is the same. I've changed nothing on the computer. I've updated my drivers. This is crazy!
EDIT: I just saw that I could post a photo- so here is what I mean:
See that the "text" is also hidden up top. There is no way I can drag and expand the tool box, or in any way "un-cover" the icons.
mrguy
Mémoire RAM : 512MB
Re: Important Icons such as Clone Stamp Tool are hidden!!
Message par mrguy »
I'm sorry!
I did a very newbie thing and posted my problem thinking I was the only one in the history of the world to have this happen to him......and failed to search for the answer in other posts.
As it turned out it was simply not compatible with my windows theme and it is all fixed now.
Please forgive my stupid first post!
thank you
Hi,
your post is not stupid at all, and it indicates that you don't content yourself with wait an answer, and you do your own research. :D
Fine behaviour :clap: and welcome to this forum.
some themes use big button size by default. It is possible to change it with a theme editor but I never do it my self and can not help your for this :oops:
