Action lines
6Hokage
Processeur : --
Mémoire RAM : --
Action lines
Message par 6Hokage »
Hi.
I was wondering, can you create an analogy of different action/tension lines for manga purposes - for example http://www.onemanga.com/Drifters/6/08/ etc
I know quite a long way on photoshop, is there a way on PF studio?
Thanx.
Re: Action lines
Hi,
You can get a similar effect with some masks and the PhotoMask Module in PhotoFiltre.
Don't forget that the softness of masks can be stronger if you apply the masks several times,
and indeed you can create the effect in any colour and turn it in negative. :wink:
Image . Image
Matej
Version de PhotoFiltre : 10.1.0
Processeur : Intel Dual Core 2,66
Mémoire RAM : 2GB 800 MHz
Re: Action lines
Message par Matej »
