How can I create line/shape curves?
Matej
Curves
Re: Curves
Hi
with a little search in International section with "curve", you can find a correct answer :
viewtopic.php?p=127084#p127084
Don't forget to read it till the end.
Matej
- Version de PhotoFiltre : 10.1.0
- Processeur : Intel Dual Core 2,66
- Mémoire RAM : 2GB 800 MHz
Re: Curves
No curves
Twirl is random effect.
Re: Curves
Perhaps with images ?
http://translate.google.com/translate?h ... 77#p142577
