Help with image animation - Ajuda com animação na imagem
claudya07
Version de PhotoFiltre : Studio 9.1
Processeur : pentium4
Mémoire RAM : 1 GB
Message par claudya07 »
Hello, i´m trying aplly some effects at a image. I´m doing this: :shock:
1) open a back
2) open a png image, copy and paste as new layer
3) selected the png layer with lasso tool, and then, aplly AAA filters Granularity 3 times, changing the configuration of noise (70/90 and 110), to have 3 jpeg files for the animation at Unfrezz.
**** Now my error, i merge visible, but the effect of Granularity over all the image (png + back)****** I want the effect only at png layer. ***** What i need to do? Use copy merged? Don´t know???? Need help please
Olá, estou tentando aplicar o plugin Granularity numa imagem prá animar. Fiz isso
1) Abri um back
2) abri uma imagem png, copiei e colei como nova layer
3) selecionei a layer png e apliquei o plugin Granularity 3 vezes mudando a config. do noise, prá ter 3 arquivos jpg e animar no Unfrezz.
****** Mas quando dou merge visible e salvo, no unfrezz o efeito do plugin passa prá toda a imagem e fica feio********** O que devo fazer? Copy merged??????? Ajuda por favor
Re: Help with image animation - Ajuda com animação na imagem
Hi,
with the Studio version, you don't need Unfreez, it has a built in Animated Gif tool. :)
Look at this page : To create animated pictures with PhotoFiltre Studio (shareware 30 days) http://jptom.free.fr/Tuto_En.html
claudya07
Mémoire RAM : 1 GB
Tom, ty, but my question is about the selection area at png file, and why my effect don´t keeps only where i selected? Why the effect goes over all image?????? I want the effect only at png file. So, i think the problem is that i´m doing wrong at the layers.... And, if i want to save the images temselves (3 jpeg files) to animate apart, what i need to do? Merge visible gets ugly! I have to copy merged???? :(
Yes you did a question and my answer is : you have to change your mind :)
You don't need to export 3 jpeg files, you need only to read the translation of official documentation
which contains some typical examples and you can observe how to work with the layers.
I have no idea why a selected area is not only processed by the AAA Granularity filter, i did the try and it works. :o
But in any case, you can't get 3 layers by applying 3 times a filter on a same layer. You have to create 3 layers.
But you need to look how it does work in several case and you will better understand the different ways to get your project.
