Pasting metafile images from clipboard
Ignace
Message par Ignace »
I am using latest version of free Photofiltre V6. I am trying to paste an image I copied from a Powerpoint presentation. This does not work. I discovered why. Copying an image from powerpoint results in a metafile format on the clipboard. Photofiltre does not recognize this. Is there a way to make this possible?
The code to handle this in Delphi should not be too complicated.
Something like this:
procedure GetBitmapFromClipboard(Bitmap: TBitmap);
var
MetaFile: TMetaFile;
begin
if Clipboard.HasFormat(CF_METAFILEPICT) then
begin
MetaFile := TMetaFile.Create;
Metafile.Assign(ClipBoard);
Bitmap.Width := MetaFile.Width;
Bitmap.Height := MetaFile.Height;
Bitmap.Canvas.Draw(0,0,Metafile);
MetaFile.Free;
end;
end;
Re: Pasting metafile images from clipboard
For the moment i can not work on the free version, lot of work with the studio version and support. I will try to works next month for a new release but not sure :cry:
Thanks for this code, i allready use it for the studio version, but a little more complex to support metafile transparency (only more few lines) :wink:
