Guys, I am quite new to this so please excuse me if I have made some simple errors.
1. When I create a graphic as a pfi file I then store it as such expected in to open it and re edit as requiered. When I go to open a text layer however the layer opens the Option sbox not the Text box. The text layer then needs to be re created which is a pain.
2. I cannot copy and paste colour codes from Dreamweaver to PhotoPhiltre or back again? This seems like a bug?
If you cold help on both of these I would be very grateful as otherwise I love the product.
Thanks Ian
Re opening pfi files
igrieves
- Version de PhotoFiltre : Studio x
- Système d'exploitation : Vista
- Processeur : Quad Core
- Mémoire RAM : 2mb
Re: Re opening pfi files
Hi,
1. i just did that you said, and i'm sorry but i don't see any problem.
I can open the text box by double clicking on the layer thumbnail or menu Layer / Options
Perhaps the pfi file was saved with a rather old version ? Or If you click on the text tool in the tool bar you get a new text layer.
2. To copy a colour code : click on the pipette tool and in the Web box do a right click / Paste
Same way for back.
Read you soon.
Same way for back.
Read you soon.
igrieves
- Mémoire RAM : 2mb
Thank you!
