problem !! ? JPEG
amd123
Version de PhotoFiltre : ph.studio
Processeur : c
Mémoire RAM : 256
problem !! ? JPEG
Message par amd123 »
unable to load image in file "........................................"
Help me please
Re: problem !! ? JPEG
Hi,
what kind of file, is it a special JPG ? which weight ? or which size in pixels ?
Have you tried to open it with "XnView import" plugin ? : http://www.photofiltre-studio.com/plugi ... hp?lang=en
Look at PhotoFiltre Plugins Pack at the bottom of the page, it install correctly the complementary dll needed.
ohmzen
Version de PhotoFiltre : 7
Système d'exploitation : windows
Re: problem loading JPEG jpg file
Message par ohmzen »
Unable to load image in file.
I found that PhotoFiltre expects the file to be as the extension indicates.
try this: open your .jpg file in a text editor, view the very first line. Does it say "png" or "tiff". then rename the file to match the identifier IN the file. You may find that is will open in Photofiltre just fine now.
