Hello
I just started to use PF and I really like it! I'm creating a layout right now but I have some questions:
1. How can I create a border around a layer? So not around some text or the whole image only around the layer.
2. How can I make round borders (around the layers)?
3. How can I make a border only at the bottom of a layer of image?
Thanks,
Reemon
Border questions
Reemon
- Système d'exploitation : Windows
Re: Border questions
Hi,
you can find some tutorials on the official web site of PhotoFiltre : http://photofiltre.free.fr/frames_en.htm
and some others on this page : http://lmquettier.free.fr/listing.html
- menu Selection / Select layer
- menu Selection / Contract
- right clic in the selection / Invert selection
- right clic in the selection / Stroke and fill / Fill and choose a colour
May be you have to go in Preferences and uncheck Draw on alpha transparency
They are many other ways to get a same result, have a look at menu Filter/Stylize/Progressive contour or Contour 3D
- like above : when you get the correct selection, right clic Set shape / Rounded rectangle
- rather easy, there i live you guess your own way, with Duplicate the layer or something like a mask perhaps ?
