Copyright
kjweed
Version de PhotoFiltre : 10
Copyright
Message par kjweed »
I am looking for some help in using the "Copyright" feature.
When I put my name in I do not see it on the picture. Am I missing it somewhere?
Thanks for any help.
Re: Copyright
Hi,
perhaps are you missing several things :) , your question is in a better place in the Graphical forum.
For the copyright, it seams a same colour for the text and the background is not very easy to read.
Don't forget that the size of the characters is done in pixels, and a 10 pixels copyright on a 5M pixels image is quite invisible.
kjweed
Re: Copyright
Thanks for the help I will try to enlarge the print. :)
