I simply LOVE Photofiltre-studio! I use it for almost all of my touchup needs.
But there is one feature missing that makes ALWAYS have to use another application in some instances: basic drawing features.
Yes, I can add a line, but I cannot not draw a simple circle, a square, etc.
What I want to be able to do is to "markup" an image by circling items and so forth.
Do you have any plans to ever add basic drawing tools?
Thanks!!!!!
Can you add simple drawing tools?
jbarr
Re: Can you add simple drawing tools?
of course it's possible, use the selection tool (ellipse, rectangle, ...) and the menu Edit > Stroke and fill. With the studio version it can be automatic
jbarr
Well I'll be!
That's amazing!
You just provided me with a solution to the ONLY thing that was keeping me from using Studio exclusively!!!
thank you, Thank You, THANK YOU!!!
That's amazing!
