Icons are not correct displayed
obiwan26
Système d'exploitation : Windows7 RC
Processeur : AMD DUAL OPTERON
Mémoire RAM : 3 GB
Message par obiwan26 »
Hello,
i have a problem with the graphic display of the icons from Photo Filtre X. I am using windows 7 64bit RC and NO Aero design and the icons look like this:
If i switch to Aero design everything is ok and the icons are normally visible.
Can anybody help?
Thanks an Best Regards
Obiwan26 :(
Dernière modification par obiwan26 le 04 août 2009 10:45, modifié 1 fois.
Re: Icons are not correct displayed
i will try to fix it for the next version 10.1.0 (september)
can you try with the last X beta 13 :
http://www.photofiltre-studio.com/tmp/pfsx1010.zip
obiwan26
Mémoire RAM : 3 GB
Hello Antonio,
and first many thanks for your quick answer and in advance for solving the problem. The Beta 13 works fine: all icons are "normal" visible :D :D
Best regards
Obiwan26
