Suggestion: Text Tool, Effects, remember Opacity
rpesq
Système d'exploitation : Vista x64
Processeur : AMD Sempron
Message par rpesq »
Hi,
RE- Photofiltre free 6.3.2
You deserve huge thanks for offering free version of Photofiltre. You are truly a nice person. The application is awesome.
I realize that free Photofiltre is probably low on your agenda, but maybe you consider a small suggestion: would you considering having the application remember the OPACITY setting for TEXT -> EFFECTS? I add watermarks to my photos, and every time I have to manually change the opacity setting to what I want. The application remembers the color of the Text, and the Size of the Text, and the font of the Text, but the Opacity always defaults to 100%. For watermarking, the opacity will usually be very low, maybe 15-25%.
Thanks for considering.
Re: Suggestion: Text Tool, Effects, remember Opacity
i will see this in the next version...
