Hallo all
Is it not posibel too import a PDF file into Artweaver ??
PDF - Import ??
trads
- Version de PhotoFiltre : 0.5.7
- Système d'exploitation : xp
Re: PDF - Import ??
Hi,
I think you are mistaken.
Here we are on the PhotoFiltre's forum.
We don't know Artweaver, but we can copy and paste some pdf elements into PF.
trads
Re: PDF - Import ??
Tom a écrit :Hi,
I think you are mistaken.Here we are on the PhotoFiltre's forum.
Hallo and thanks
Sorry my mistake !!
But i now downloade PF. And i cant import a PDF file ??
Re: PDF - Import ??
What do you want finaly to do with the pdf file ?
trads
Re: PDF - Import ??
Hallo
use it and change the picture as a dwg file !
Re: PDF - Import ??
No, dwg is not a file type that PF can write.
But, in any PDF reader, some tools allows you to copy text or image and than you can paste it in PF.
File types whiche may be writen by PF are : bmp, gif, jpg, jpeg, jpe, jfif, png, rle,tga,tif, tifff
