Print Issue
willemeulen
Processeur : 1.73Ghrz
Mémoire RAM : 2GIG
Print Issue
Message par willemeulen »
I use Photo Filtre to print immages from Google Earth.
Not long ago the printing went fine to a color printer and all the smaller immages where on the same scale and fit nicely together.
Now since yesterday doing the same exersize the printer produces empty pages unless I fumble with the printer settings/scale to fit etc. The immage I'm printing now is actually smaler than the immage which still prints as last week.
What could be the trouble?
Thanks,
W :mrgreen:
Re: Print Issue
Hi,
no idea for this behaviour, it depends of :
  • the size in pixels of the image (and perhaps its resolution, if you use to work in inch or cm)
  • and the size in pixels of the default page of your printer ?
By default, the printing module displays the image at 80% compared with the default page size in pixels.
