Colors in a drawing keep changing
Dawna
Version de PhotoFiltre : 10
Système d'exploitation : Vista service pack 1
Processeur : "not available"
Mémoire RAM : 11.4 GB (?)
Message par Dawna »
Hi,
I am working on a drawing using PhotoFiltre that is taking a long time to complete. I am saving the drawing when I finish my work every day, but I have noticed that when I reopen PhotoFiltre the next day, the colors have drifted and are really very different from what they were when I first put them on the drawing. They look kind of muddy, especially the reds. The reds also look blotchy.
Is this a bug in the program? Or is it something to do with my computer? Has anyone else had this problem? Does anyone know what the solution is?
Other than that, I am very happy with the program.
If anyone could help and explain in simple terms what I can do to correct this, I would be grateful.
Thanks,
Dawna
Re: Colors in a drawing keep changing
saves as png not as jpeg :wink:
Dawna
Message par Dawna »
Thank you! I'll do that.
Dawna
