so i just got Photofiltre Studio X, and i cant figure out how to change the size of the text like in PF free, like moving the size with arrows. how can you do that? cuz the only size change thing i see is when you type the text in and the size is there
[Tom] Je déplace depuis tutorials [/Tom]
text help
Re: text help
Hi and welcome to kindly begin
In The text module of PF6 there are two arrows at right of the text size.
In the PFS's text module i find a single arrow, instead of, but it's not a simple design ;
perhaps something would happends, like a kind of pop-up list, if you click on it ?
Sometimes you can also enter a value in the field, isn't the case ?
jeffagogo
- Version de PhotoFiltre : 6.2.7
- Système d'exploitation : windows XP SP3
- Processeur : Pentium 4
- Mémoire RAM : 368MB
Re: text help
No...what he means is, when you have entered some text in Photofiltre 6 the result is a box with 'dancing ants' around it i.e. it's in selection box. You can grab it by the side or corner to expand/distort the text and also move the block of text around.
However in Photofiltre Studio this is different(from what I've noticed) the resulting selection box with text inside doesn't allow you to expand and contract the block of text..although you can move the block of text around. Does PFS not allow you to contract/expand/compress text like in Photofiltre 6?
Re: text help
==> With PF6 after contract the text you can not change the text content !
with the studio version you can, and it's better to change the font size than using the deformation tool. But if you really want to deform the text convert it to image layer. And after yoy can apply all filter and deform tool
Re: text help
Oh sorry djjay if i have misunderstood
Thanks jeffagogo.
Thanks jeffagogo.
