Toolbar-buttons not accessible with certain Visual Styles
BugReporter
Message par BugReporter »
hi,
I just found out about ur great program and directly ran into a problem with the toolbar. I use the Opus OS 1.5 Visual Style for windows (http://www.deviantart.com/deviation/4591314/) and with this skin its not possible to access the lower buttons of the main-toolbar. the buttons are displayed to big, as u may see on the screenshot. due to the fact, that the toolbar doesn't show proper sizes and also doesn't react to the improper sizing of the buttons, the cloning-brush and some other buttons are not visible anymore (especially in docked mode).
its likely to happen with different visual styles.
maybe this can surpassed.
greets! :)
the screenshot:
Hi BugReporter,
Independently of any skins for windows, some tools of the graphic toolbar are not active when :
- the color mode is not RVB, like with a gif file. Then you have to click on the icon of RVB Colors or in menu Image / Mode / RVB colors
- transparency is activated on the image. Then you may open menu Image / Transparency color / Deactivate transparency.
If these two ways don't match, you can invoque an other problem like a skin one, but for this last i could'nt answer.
Tell us if the problem will continue. Thanks.
i don't understand why the skin change the button size :cry:
You can try to disable advanced draw in the menu Tools/Preferences/Startup
BugReporter
hi again,
I already tried out every options, but it doesn't help. the buttons are there, but not accessible. the amount of "disappearance" seems to depend on the visual style used. in my case the buttons the lower buttons are absolutely unavailable (even if they should be available) in docked mode. the only work around (for my used skin at least!) is that I make the toolbar undocked and restart the program. this way the lower buttons appear at an amount of 2pixels, which makes the clickable after all.
hopefully u find a way to get around this. :)
greets!
