Circles and elipses
davryn
Circles and elipses
Message par davryn »
How do I draw a colored circle or elipse around part of an image.
I love the lens plugin and I use the arrows all the time. Are there also more arrows to download and install?
Thank you,
Davryn
Re: Circles and elipses
Hi,
have a look on this page : http://photofiltre.free.fr/tutorials_en.htm
Just do a right clic in a selection and Stroke or fill
For add-ons on this page : http://www.photofiltre-studio.com/addones-en.htm
davryn
Thank you for the reply but I am confused. You said to right click in a selection and stroke or fill; however, I don't see how that will allow me to draw a circle or elipse around something on an image. Is there a trick to make a circle or elipse appear sort of like the lens plug-in where I can add it and size it to show something in a photo?
Ideally I would like to be able to highlight an area with a circular or elliptical line to highlight what is in the area.
Sorry to be a pest but I don't understand how to do what you suggested.
Thank you,
Larry
Tom a écrit :Hi,
Hi,
do it first : draw an elliptic selection, do a right clic and use stroke. :D
You will have plenty of time forward to understand how. :wink:
davryn
Tom:
Thanks again for your reply.
Here I am again. My problem is how do I draw an elipse or circle? Is there a command that allows me to click and drag a circle or elipse like I can do with a rectangle?
Larry
Tom a écrit :Hi,
Yes you've found. :clap: Image
