Making brushes and more images for PhotoPNG ...
frangipan
Système d'exploitation : windows xp home
Processeur : AMD Athlon64 X2 4200
Mémoire RAM : 512MB
Message par frangipan »
How do I make customised brushes and more images for PhotoPNG?
I've tried to do both with no success whatsoever.
I've got the 30 free trial at the moment. If I can't figure out how to do the above there really won't be any point in purchasing the software.
I've gone through the FAQ and checked out the rest of the forum but I still need help.
Thanks in advance.
Re: Making brushes and more images for PhotoPNG ...
Hi,
All the good informations for the software are on the official site :
http://www.photofiltre-studio.com/reg-en.htm
The brushes must be saved in a strictly square png in RGBA mode
I think it would be also some RGBA pictures in PhotoPNG. :wink:
frangipan
Mémoire RAM : 512MB
I followed your advice re saving png in alpha mode and have successfully made my first PhotoPNG image. Go me! :clap:
Thank you very much indeed. :mrgreen:
