Hello!
How can I create an automatic selection or alpha channel from two layers' difference?
I tried diffuse and difference blend modes, and manual selecting the "difference", but it was too complicated.
The layers are an animation file's frames.
thank you
layers difference
justask
- Version de PhotoFiltre : Studio 9.2.2
- Processeur : Core2Duo
- Mémoire RAM : 3 GiB
Re: layers difference
Hi justask,
I'm not sure if i had the question well understood.
But i will try two manners :
- The quickest i mean : copy merged
- menu Layers / Hide all layers
- switch as Visible the combined layers
- select the upper layer and menu Edit / Copy merged
- paste, you have a new layer, as a merged result, you can edit its alpha channel.
- Edit the alpha channel of the both layers
- menu Adjust / Negative for one of them and copy
- paste on to the other alpha channel and set the blending mode
in minimum or maximum, depending the result you wish
justask
Thank you for fast response.
But I think you misunderstood my question. It is my fault, my english is poor.
So I am trying to explain:
There are 2 image/layer. These images are frames from an animation/a movie. How can I detect the different part of the two frame/image/layer?
Just like a text file comparison, or a binary file comparison.
I need the selection(s) for the different part(s), or alpha mask (the not changed part is transparent, and the changed one is visible).
I hope my question is much clearer.
thank you
thank you
Hi,
Yes, the question is much clearer, but ...
it's a dreamed comparison, but it doesn't work like that in any image editing program i know.
That's exactly i have understood, but again ...
- an alpha mask returns only the solid, transparent, and relative transparent areas of a layer,
It doesn't return any information on a detail or another which are on a solid area between many other details.
- in a alpha mask, transparent areas of the layer are return as black color, solid as white, and relative transparent as relative grey colors.
- to apply the alpha mask on a layer you have to copy the alpha mask and select the layer : menu Layer / Transparency / Paste as Alpha channel
I don't know any manner to display only what has changed on the front of the layers, perhaps is it possible ??? but i don't believe,
on the other hand, the second way of my last post can return what has changed in Alpha channel (transparency) between two layers.
justask
OK, thank you very much for your answer.
